plz help me
Solved! Go to Solution.
You can create a service that references data from the postgre database and then use this service in your Android application.
Please take a look in the documentation below for the supported geodatabase formats
Supported geodatabase formats—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
im beginner to android plz suggest me sum more examples.
Feel free to take a look at the following.
Access feature data in the cloud—ArcGIS Runtime SDK for Android | ArcGIS for Developers
You can just replace the url to the feature service with your feature service that will point to a postgre database.
Also the following might be helpful for starting with ArcGIS API for Android
Hello World - This is the most basic sample
arcgis-runtime-samples-android/HelloWorld at master · Esri/arcgis-runtime-samples-android · GitHub
Sample Code - This is a document that describes how to access all our Android samples
