outFeatureClass/arcpy.CopyFeatures_management
4123
13
12-29-2015 04:47 AM
CliveSwan
Occasional Contributor II
I need to automate a shapefile to feature class update. The problem is that the shapefile name and output (feature class) are not the same.
So I need to hard code the shp & features.
I have a loop that works, printing out the shapefile names.
The code fails when I try to use the arcpy.CopyFeatures_management function.
Can anyone see what is causing the arcpy.CopyFeatures_management function to fail??
Would appreciate a suggestion to resolve the issue.
import arcpy
import glob
import os
import sys
import csv
import time
import smtplib
import shutil
import ftplib
sdeConnection = arcpy.env.workspace = r"C:\database_connections\GIST.sde"
outWorkspace =sdeConnection
datadir = arcpy.env.workspace = r"\\server1\ER Shares\Highway_Layer_Update" ## URL works
try:
    #check file exists here
    fcList = arcpy.ListFeatureClasses()
    ## Feature classes are hard coded
    for i in fcList:
        if i == "Bus Stops.shp":
            #outFeatureClass = os.path.join(outWorkspace, shapefile.strip(".shp"))
            #arcpy.CopyFeatures_management(shapefile, outFeatureClass)
            print i  ## NO shp
            fcnew = "GISADMIN.KCC_BUSSTOPS_NEW"
            outFeatureClass = os.path.join(outWorkspace, fcnew )
            arcpy.CopyFeatures_management(i,  outFeatureClass)
            arcpy.DeleteFeatures_management(i)
        elif i == "Cluster_sites_2014.shp":
            print i            ## Prints shp
            fcnew = "GISADMIN.KCC_KHS_CLUSTERS_2014_NEW"
            outFeatureClass = os.path.join(outWorkspace, fcnew )  ## Fails
            printoutFeatureClass
        else:
            print "No file"
except:
    print ("No File found program terminated")  ## This is printed out
Message was edited by: Dan Patterson I formatted your code to make it easier to read... use the syntax highlighting ... >> ... and select Python
DanPatterson_Retired
What's up with line 36?   printoutFeatureClass   perhaps print outFeatureClass
So you are saying that it failed.  Did you get an error message? and if so, what was it.
CliveSwan
A typo,
I just printed out the except block message, not helpful.
Thanks.
JamesCrandall
MVP Frequent Contributor
I'd try to uncover what the actual error is first.  You can either simply remove the try/except block and it should print the traceback, or just update your except to print the actual error rather than "No File found program termintated" (you will need to add another import statement with the code below...
import traceback
  try:
     'do stuff
  except:
      exc_traceback = sys.exc_info()
      print traceback.print_exc()
I agree with James.  People spend more time trying to debug try-except blocks...or worse interpreting them.   Having the listfeatureclasses within the try except block is an example.  If you had that line outside, followed by a print statement, you would at least know it got that far.  Also, a judicious use of print statements will allow you to see at each step whether a block succeeded.
CliveSwan
Hi James,
That provides a far more useful error message.
Clive
JamesCrandall
As Dan mentioned, the try/except block can be a double-edge sword sometimes, especially at design-time.
I personally don't really employ them until I'm ready to build a test deployment version because I just want to see the tracebacks when they hit the Interactive Window (PythonWin).  Even then, the print or arcpy.AddMessage methods don't help much for much of my deployed implementations and I will typically use these try/catch blocks for writing out log events.
As an example...consider the variants of the simple script...
Header 1Header 2
# version 1
print(something)
  File "C:\Python34\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 326, in RunScript
    exec(codeObject, __main__.__dict__)
  File "F:\B_Python_3_\Python_1_to_edit\try_except_demo.py", line 1, in <module>
    print(something)
NameError: name 'something' is not defined
# version 2
try:
    print(something)
except:
    print("ooops")
>>> ooops
# version 3
import sys
import traceback
try:
    print(something)
except:
    print(traceback.print_exc())
  File "F:\B_Python_3_\Python_1_to_edit\try_except_demo.py", line 5, in <module>
    print(something)
None
Now...when developing scripts, I will leave it to the user to decide which is quicker in finding errors (dumb or otherwise) and which is the more informative
JamesCrandall
Great illustration.
I just started using the exc_traceback to simplify the error as I rarely need (or understand!) the error and line references to the actual modules/packages.  But most of the time I don't even have try/catch during development!
True... and since we have hijacked the thread, no one else cares and since you use pythonwin... the barebones error from the scriptutils.py script
("C:\Python34\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py")
tries to execute line 326.  Which I found was the line where...when everything else fails...pythonwin, finally tries to execute the script code using the variable from the dictionary
and of course, there is nothing in...
>>> locals().keys()
dict_keys(['__builtins__', '__loader__', '__doc__', 'pywin', '__name__', '__spec__', '__package__'])
called 'something'
