Doubts about MIl 2525c Symbology
2666
12-27-2015 08:27 PM
Bhargav_KumarK
I am working on sample Advanced Symbology->Symbol Dictionary given in Arc GIS Qt Samples. As given in the sample we are able to draw symbols, move the symbol(using the call EsriRuntimeQt::MessageHelper::createUpdateMessage) but I am not able to select the symbol which I drawn on map.
In the documentation I found out that in order to select symbol I can use function
static Message EsriRuntimeQt::MessageHelper::createSelectMessage    (    const SymbolDictionaryType &     type,
const QString &     messageId,
const QString &     messageType,
const bool &     highlight
How to use this function in order to achieve selection of symbol?
LucasDanzinger
Esri Frequent Contributor
Bhargav-
There seems to be a bug in our select method, which is setting the "_action" property incorrectly. Luckily, there is a workaround.
Can you try something like:
Message selectMsg = MessageHelper::createSelectMessage(SymbolDictionaryType::Mil2525C, “message_id”, “position_report", true);
selectMsg.setProperty(“_action”, “select”);  // set _action property to “select” or “un-select”
m_groupLayer->messageProcessor()->processMessage( selectMsg ); // process select message
LucasDanzinger
Bhargav-
Bhargav_KumarK
Thanks Lucas Danzinger. It is working as you told.
How to select these graphics on mouse click?
I got these in one way,
EsriRuntimeQt::GraphicsLayer* m_graphicsLayer = (EsriRuntimeQt::GraphicsLayer *)m_messageGroupLayer->get(0);
connect(m_graphicsLayer, SIGNAL(graphicIdsComplete(const QList<qint64>&)), this, SLOT(onGraphicIdsComplete(const QList<qint64>&)));
m_graphicsLayer->graphicIds(event.x(),event.y(), 10);
void Symbology::onGraphicIdsComplete(const QList<qint64>& hitGraphicIDs)
  qDebug()<<"in graphic ids complete";
  EsriRuntimeQt::GraphicsLayer *m_graphicsLayer = (EsriRuntimeQt::GraphicsLayer *)m_messageGroupLayer->get(0);
  for (int i = 0; i < hitGraphicIDs.length(); i++)
    if (!m_graphicsLayer->isGraphicSelected(hitGraphicIDs.at(i)))
      m_graphicsLayer->select(hitGraphicIDs.at(i));
    else
      m_graphicsLayer->unselect(hitGraphicIDs.at(i));
I am able to select mil2525c symbol created by using above procedure. Is there any other way to select graphic(mil2525c graphic) on mouse click?
