Using setScale(8000) and (12000) does not see map scale change
2389
12-28-2015 06:44 AM
fuliaoli
New Contributor III
In my app, when I click scale(24000) and (12000), I see the map changes as scale changes. But from 8000 to 12000, there is no change.
Are there some fixed scale tiles set in ESRI base maps?  I don't have much experience of map documents.
Thanks in advance,
li
TimWitt2
Yes you are right, depending on the scale it loads new tiles.
TimWitt2
fuliaoli
New Contributor III
Hi Tim,
Thanks a lot for your quick response.
Regards,
li
