Export data in model builder
5129
11
12-23-2015 08:48 PM
kapildev
New Contributor III
I have 200 cities data in different feature class in one FGDB. My problem is i want to export data according to cities in different different folder and GDB in modal builder. so please tell me how to do this. Thanks in advance
Input is show below...
Output that i Want
ChrisDonohue__GISP
In Modelbuilder one way to do this would be to use an Iterator to loop through the Feature Dataset, then have a function to create a new geodatabase as it loops each time.  The name could be transferred across from the iteration to your new geodatabases through the use of a in-line variable substitution.
Iterator examples
ArcGIS Desktop
In-line variable substitution
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Chris Donohue, GISP
kapildev
New Contributor III
tnx
But its create Only gdb. its not transfor data that we have.
DanPatterson_Retired
Moved to Managing Data
since this is not Education specific
WesMiller
Regular Contributor III
Just for fun I tested tested Chris Donohue, GISP ​suggestiion your model would look similar to the one in the graphic below. You will not need an in-line variable the iterate Feature tool output is available for use in the name for create File Geodatabase tool.
curtvprice
MVP Esteemed Contributor
Wes, I think the model you set up needs one more step, a Copy Features tool to copy the input points to the newly created feature class.
kapildev
New Contributor III
Thanks Curtis Price for help me
But copy feature tool are not work. so tell me how to use this tool in model builder & which function are used in copy feature tool.
Thanks in advance
WesMiller
Curtis Price ​is correct see below.
kapildev
New Contributor III
Thanks for help
WesMiller
Curtis on the far right side I noted the precondition you may have to scroll to see it(see above). Thanks
