AnsweredAssumed Answered
Using arcpy.CreateMapSDDraft with an existing cached Map service
Question asked by gtardini on Dec 22, 2015
I'm trying to create a .sddraft with arcpy.CreateMapSDDraft starting from an already existing cached Map Service (with a custom defined Tile Scheme) published on ArcGIS Server 10.3.1, in order to republish it.
Looking into the .sddraft generated I notice that it doesn't pick up the right setting for the cache. MinScale, MaxScale and the cache schema are set to the standard Bing values, and not to my existing service's settings.
On the contrary if I generate the .sddraft with ArcGIS Desktop, the values in the .sddraft file generated are correct.
Is there a way to have arcpy.CreateMapSDDraft read the correct cache values from the existing service?
Outcomes
