Include 'TIME' with Date field for Popup works but nothing exists for Query Results?
3445
12
12-18-2015 09:27 AM
MichaelRobb
Occasional Contributor III
I have a question if this requires customizing or if I have missed a means of having this work out of the box.
Scenario
Web Map.  Configuring Popup, you can select to have Time included with Date field (Configuration)
As seen here:
The change would produce the following in a feature popup:
In the Web application Query widget... pointing to the same layer... If a Query is Initiated, the result as well as the Popup when clicking on the result shows the following:  (No Time)
Thoughts?
RobertScheitlin__GISP
Michael,
  OK, the change for 1.2 is simple to get the time to show.
In the Widget.js for the Query widget find the _tryLocaleNumber function and change the code from:
       _tryLocaleDate: function(date){
        var result = jimuUtils.localizeDate(date, {
          selector: 'date'
        if(!result){
          result = date.toLocaleDateString();
        return result;
to:
        var result = jimuUtils.localizeDate(date);
        if(!result){
        return result;
Michael,
   The query widget produces a layer using the query results and that new layer is not using the popup defined in the webmap, but the one defined in the Query widget UI.
MichaelRobb
makes sense.  So I need to change the query code to be able to include Time?  I dont see any configuration ability in the Query Widget to also have time be included in date field calls.
Results settings only has the following:
Michael,
   By default the date field if it includes time will be displayed with date and time. Here is an example image of my app that has a date field and it is showing the time.
MichaelRobb
Then something is wrong as the field contains Date/Time information as shown above when enabling with the custom popup.
Michael,
  I just tested another layer with date and time and same result it shows up automatically. I am testing in WAB 1.3
MichaelRobb
Perhaps this works in Version 1.3 and not in 1.2. (sigh)
I just tried a new blank new Web App, and get the same result (no TIME).
MichaelRobb
Here is a screen shot of the Attribute Table in the same Test Web App..
Michael,
          selector: 'date'
        if(!result){
        return result;
to:
        if(!result){
        return result;
MichaelRobb
How does one learn WABde as much as you have?
Thanks for showing that a simple selector bit of code is there and simply needs to be removed.
This of course means I can select TIME only or DATE only at any instance.
          selector: 'date'
