I really enjoy the layout of the Map Journal Builder with the Floating Panel. The only downside is that I want to change the color of the panel. What part of the downloaded code can I edit to change the color?
Solved! Go to Solution.
After you have downloaded and got it running on your server look here:
Esri/map-journal-storytelling-template-js · GitHub
It might take some css work but it is possible.
