Create a marker mask from a representation
2436
12-18-2015 01:11 AM
CedricDELPAS
I have created a tool in C# in order to create Mask symbol around the symbol feature.
To do that, I use the IMarkermask interface and the QueryMarkerMask function.
Like this:
IGeoFeatureLayer iGFL = iL as IGeoFeatureLayer;
if (iGFL != null)
     IFeatureRenderer iFR = iGFL.Renderer;
     if (iFR != null)
          IPolygon iPG = new PolygonClass();
          ISymbol iS = iFR.get_SymbolByFeature(iF);
          if (iS != null)
               IMarkerMask iMM = iS as IMarkerMask;
               if (iMM != null)
                    IGeometry iGShape = iF.ShapeCopy;
                    if (iGShape != null)
                         iGShape.Project(ESRI_Constant.Object._FocusMap.SpatialReference);
                         pAV.ScreenDisplay.StartDrawing(pAV.ScreenDisplay.hDC, 0);
                         iMM.QueryMarkerMask(pAV.ScreenDisplay.hDC, iDRet, iGShape, iPG);
                         pAV.ScreenDisplay.FinishDrawing();
It works fine for a layer with a classic symbology.
But if the layer use a Representation as symbology, this code doesn't work: the line ISymbol iS = iFR.get_SymbolByFeature(iF) return null.
How can I get an ISymbol from a feature using an IRepresentationRenderer?
Or, more generally, how can I get a mask geometry for a Marker representation?
Thanks!
Best regards
