Hi guys, I'm still beginner again ...
I've installed and configured "Javascript API" in windows.
Now, I'm testing the examples but I have the following question
In the lines of code alone put JSAPI route:
1. <script src = "http: // <myhosting> /arcgis_js_api/library/3.15/3.15compact/"> </ script>
or
2. <script src = "http: // <myhosting> /arcgis_js_api/library/3.15/3.15/"> </ script>
When I test the example, the error "Access Denied" is displayed, I have solved with the full path of "Init.js" in each
1. <script src = "http: // <myhosting> /arcgis_js_api/library/3.15/3.15compact/init.js"> </ script>
or
2. <script src = "http: // <myhosting> /arcgis_js_api/library/3.15/3.15/init.js"> </ script>
Is it right to put the full path? .....
Also if I try ESRI path redirects me "Init.js".
You can try it: https://js.arcgis.com/3.15/
Someone can tell me how I can do this redirect
Thank you very much for your answers?
