Using multivalue parameters in a custom toolbox script
3734
12-14-2015 09:09 AM
BenjaminSimpson
New Contributor III
I have a custom toolbox which I added a python script too. The script currently runs when the input parameters are not multivalue, but the script falls over when I set the input parameters to multivalue. Where they seem to be falling over is when I try to use pyodbc to connect to an access database. I am currently using the arcpy.GetParameterAsText function and then using the split function to separate the semicolon delimited string into a list.
This is the error information that I am currently receiving.
Error Info:
<class 'pyodbc.Error'>: ('HY000', "[HY000] [Microsoft][ODBC Microsoft Access Driver] Not a valid file name. (-1044) (SQLDriverConnect); [01000] [Microsoft][ODBC Microsoft Access Driver]General Warning Unable to open registry key 'Temporary (volatile) Jet DSN for process 0x1200 Thread 0x128c DBC 0x24d28a4 Jet'. (1); [01000] [Microsoft][ODBC Microsoft Access Driver]General Warning Unable to open registry key 'Temporary (volatile) Jet DSN for process 0x1200 Thread 0x128c DBC 0x24d28a4 Jet'. (1); [HY000] [Microsoft][ODBC Microsoft Access Driver] Not a valid file name. (-1044)")
A snippet of my code:
import arcpy
import pyodbc
import sys
import os
import pythonaddins
SAGIS_Input = arcpy.GetParameterAsText(0)
SAGIS_model_new = SAGIS_Input.split(";")
SAGIS_Count = len(SAGIS_model_new)
arcpy.AddMessage(SAGIS_Count)
for model in SAGIS_model_new:
     SAGIS_model = str(model)
     arcpy.AddMessage(SAGIS_model)
     # connection to SAGIS model geodatabase
     access_conn = pyodbc.connect('DRIVER={Microsoft Access Driver (*.mdb)};DBQ='+SAGIS_model)
     access_cursor = access_conn.cursor()
     tablelist = arcpy.ListTables()
     tablecount = len(tablelist)
     arcpy.AddMessage(tablecount)
     arcpy.AddMessage("Script run successfully.")
     #print "Script run successful."
     access_cursor.close()
     access_conn.close()
I would very much appreciate any advise on how to get the muiltvalue paramters to work with the pyodbc connection.
Thanks in advance.
Ben.
Luke_Pinner
MVP Regular Contributor
ArcGIS wraps parameters with spaces in them in single quotes when passing multivalue parameters.
If I run the following script as a toolbox script tool and pass it "a b c" and  "abc" as the first parameter, I get the below output
import arcpy
  arcpy.AddMessage(model)
Notice the single quotes around the values 'a b c'?
You need to strip them off with something like:
  model = model.strip("'")
FreddieGibson
Occasional Contributor III
Have you tried adding a message to the dialog to verify the name returned for your model? The values should come in as a string delimited by semi-colons. I would assume that most likely the quotes may be coming in if you have spaces in the strings and you need to strip them out.
Luke_Pinner
import arcpy
BenjaminSimpson
New Contributor III
Thank you both for your helpful advice. Stripping the single quotes worked a treat. Your help is much appreciated.
