Pop-up: ArcGIS Online vs ArcGIS Server
2699
12-14-2015 11:54 PM
OscarDiago
Hi!
Which pop-up has preference? One stablished in ArcGis Server or the one I configure in ArcGis Online?
I'm using a layer stored in ArcGis Server that has a pop-up configuration to show in ArcMap. Now I have to use the same service for a map viewer I'm developing in ArcGis Online. I enable the pop-up window for that layer, but when I click on an element it says "no information has been found".
Could be a conflict between the two pop-up configurations?
Thanks for reading!
RobertScheitlin__GISP
Oscar,
   The popup established in ArcMap is not used by AGOL and you will need to enable and configure popups for each layer you want them for in AGOL nap Viewer.
Configure pop-ups—ArcGIS Online Help | ArcGIS
Oscar,
