AnsweredAssumed Answered
add csv file custom widget
Question asked by zhangj_neorsd on Dec 11, 2015
Latest reply on Dec 15, 2015 by zhangj_neorsd
I am trying to create a custom widget AddCSVfile using the code i found on
Drag and drop to display data | ArcGIS API for JavaScript   to upload a csv file and then plot the points to the map.  Following is the code for widget.js i am working on, I keep getting http://machinename.domain:3344/webappbuilder/apps/widgets/AddCSVfile/reflect.ashx 404 (Not Found). Although when i am able to access http://machinename.domain:3344/webappbuilder/apps/widgets/AddCSVfile/reflect.ashx from the browser.
Any help is appreciated!
Jin
define([
  'dojo/_base/declare',
  'jimu/BaseWidget',
  "esri/config",
  "esri/domUtils",
  "esri/graphic",
  "esri/InfoTemplate",
  "esri/map",
  "esri/request",
  "esri/urlUtils",
  "esri/dijit/InfoWindowLite",
  "esri/geometry/Multipoint",
  "esri/geometry/Point",
  "esri/geometry/webMercatorUtils",
  "esri/layers/ArcGISDynamicMapServiceLayer",
  "esri/layers/ArcGISImageServiceLayer",
  "esri/layers/FeatureLayer",
  "esri/symbols/PictureMarkerSymbol",
  "dojo/dom",
  "dojo/dom-construct",
  "dojo/json",
  "dojo/on",
  "dojo/parser",
  "dojo/_base/array",
  "dojo/_base/lang",
  "dojox/data/CsvStore",
  "dojox/encoding/base64",
  "dijit/Dialog",
  "dijit/layout/BorderContainer",
  "dijit/layout/ContentPane",
  "dojo/domReady!",
  'esri/Color',
  'dojo/sniff'
  function (
  declare,
  BaseWidget,
  esriConfig,
  domUtils,
  Graphic,
  InfoTemplate,
  Map,
  request,
  urlUtils,
  InfoWindowLite,
  Multipoint,
  Point,
  webMercatorUtils,
  ArcGISDynamicMapServiceLayer,
  ArcGISImageServiceLayer,
  FeatureLayer,
  PictureMarkerSymbol,
  dom,
  domConstruct,
  JSON, on, parser, arrayUtils, lang, CsvStore, base64,
  sniff) {
  return declare([BaseWidget], {
  baseClass : 'jimu-widget-addcsvfile',
  portalUrl : 'http://www.arcgis.com',
  arrayFeatureLayer : null,
  startup : function () {
  this.inherited(arguments);
        esriConfig.defaults.io.corsEnabledServers.push("serverapi.arcgisonline.com");
        esriConfig.defaults.io.proxyUrl = 'http://serverapi.arcgisonline.com/proxy/proxy.ashx';
  on(this.uploadForm, "change", lang.hitch(this, function (event) {
  var fileName = event.target.value.toLowerCase();
  this.arrayFeatureLayer = [];
  if (sniff("ie")) { //filename is full path in IE so extract the file name
  var arr = fileName.split("\\");
  fileName = arr[arr.length - 1];
  if (fileName.indexOf(".csv") !== -1) { //is file a zip - if not notify user
  this.uploadFile(this.files);
  } else {
  this.uploadstatus.innerHTML = '<p style="color:red">Add a .csv file</p>';
  onOpen : function () {
  console.log('onOpen');
  onClose : function () {
  console.log('onClose');
  onRemoveCSVfile : function (evt) {
  if (this.arrayFeatureLayer.length > 0) {
  arrayUtils.forEach(this.arrayFeatureLayer, function (currFeatureLayer) {
  this.map.removeLayer(currFeatureLayer);
  }, this);
  uploadFile : function (files) {
  if (files && files.length === 1) {
  console.log("handle files");
  handleCSV(files[0]);
  } else {
  this.uploadstatus.innerHTML = '<p style="color:blue">Uploading…</p>';
  request({
  url : "widgets/AddCSVfile/reflect.ashx",
  form : this.uploadForm,
  load : this.requestSucceeded,
  error : this.requestFailed
  handleCSV : function (file) {
  console.log("Processing CSV: ", file, ", ", file.name, ", ", file.type, ", ", file.size);
  if (file.file) {
  var decoded = bytesToString(base64.decode(file.data));
  processCSVData(decoded);
  } else {
  var reader = new FileReader();
  reader.onload = function () {
  console.log("Finished reading CSV data");
  processCSVData(reader.result);
  reader.readAsText(file);
  requestSucceeded : function (response) {
  this.uploadstatus.innerHTML = '<p style="color:blue">Upload success…</p>';
  this.handleCSV(response);
  requestFailed : function (error) {
  //this.uploadstatus.innerHTML = '<p style="color:blue">unable to upload</p>';
       console.log(JSON.stringify(error));
Outcomes
