CE 15.2 crashing on launch.
4789
8
12-09-2015 10:18 AM
ChristopherZoog
Hi All,
I am having a problem with city engine crashing as after it acquires it's license from our license server but before the application has a chance to appear.  The loading screen disappears and am I left with a java error dump on my desktop.  I've attached the error log to this post, and my system specs are below.  I have also tried 15.0, same issue, can anyone help?  Thanks!
Overview:
Dell Precision M4800
FirePro Software Version - 15.11
FirePro Software Edition - Crimson
Windows Version - Windows 7 (Service Pack 1)
System Memory - 32 GB
CPU Type - Intel(R) Core(TM) i7-4910MQ CPU @ 2.90GHz
Software:
FirePro Settings Version - 2015.1118.123.2413
Driver Packaging Version - 15.30.1025-151117a-296575C
Provider - Advanced Micro Devices, Inc.
2D Driver Version - 8.1.1.1533
Direct3D® Version - 9.14.10.1162
OpenGL® Version - 6.14.10.13416
OpenCL™ Version - 2.0.4.0
AMD Mantle Version - 9.1.10.99
AMD Mantle API Version - 98309
AMD Audio Driver Version - Not Available
Hardware:
Graphics Card Manufacturer - Powered by AMD
Graphics Chipset - AMD Radeon R9 M200X Series
Device ID - 6821
Vendor ID - 1002
SubSystem ID - 05CC
SubSystem Vendor ID - 1028
Revision ID - 00
Bus Type - PCI Express 3.0
Current Bus Settings - PCI Express 3.0 x16
BIOS Version - 015.036.000.006
BIOS Part Number - BR46304.001
BIOS Date - 2015/04/29 05:42
Memory Size - 2048 MB
Memory Type - GDDR5
Memory Clock - 1125 MHz
Core Clock - 775 MHz
Total Memory Bandwidth - 72 GByte/s
2D Driver File Path - /REGISTRY/MACHINE/SYSTEM/ControlSet001/Control/Class/{4d36e968-e325-11ce-bfc1-08002be10318}/0001
ChristopherZoog
Hey all,  I was able to correct the problem, but i had to roll back to previous AMD driver, as the relatively new crimson AMD driver seems to not be compatible with CE as it stands now.
ThomasFuchs
Hello Christopher,
Thank you for reporting this issue.
For system testing I use similar system:
CPU Type - Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
Graphics Chipset - AMD Radeon (TM) R9 200 Series
Windows Version - Windows 8.1
I tried to reproduce the issue with:
Radeon Software Version - 15.11
Radeon Software Edition - Crimson
and had no issues.
Do you use special settings in your driver?
Your help is very appreciated!
timrobinson
New Contributor III
Hi Thomas,
I'm having a related, similar issue arising from a Firepro driver. The same machine is fine running CE2013.1, build 140203, and CE2014.0, build 140522.
The software launches, then hangs when opening a scene. The graphics driver restarts, software is then seized and needs forcing out.
Unfortunately, Window Action centre does not seem to have kept a record of what it recommended, in case that was of use...
Key information:
OS Name             Microsoft Windows 7 Enterprise
Version 6.1.7601 Service Pack 1 Build 7601
System Manufacturer    Hewlett-Packard
System Model   HP EliteBook 8470w
Processor            Intel(R) Core(TM) i7-3820QM CPU @ 2.70GHz, 2701 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date          Hewlett-Packard 68ICF Ver. F.04, 12/06/2012
Hardware Abstraction Layer        Version = "6.1.7601.17514"
Installed Physical Memory (RAM)             16.0 GB
Graphics: AMD Firepro 2000, 1GB RAM
Graphics Driver version: 12.104.2.0 (29/05/2013)
Error report from Windows
22/12/2015 2:34 a.m.      Application
Hang              The program
CityEngine.exe version 2015.2.2106.64 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel.
 Process ID: 227c
 Start Time: 01d13c603ee24b3b
 Termination Time: 32
 Application Path: C:\Program Files\Esri\CityEngine2015.2\CityEngine.exe
 Report Id: 739dd8d9-a854-11e5-951f-028037ec0200
ThomasFuchs
Hi Tim,
Thank you for your report.
Have you tried to update to a newer driver version?
Maybe your problems are linked to this known issue:
CE crashes on machines with ATI graphics cards
timrobinson
New Contributor III
Hi Thomas,
thanks for the ppointer towards the general ATI issue. I'll see if we can avoid the issue by using the preferences options...once I'm back to work in the new year...!
thanks!
timrobinson
New Contributor III
Hi Thomas,
I've had a chance to test out playing with the recommended option for dealing with the ATI cards (turning off the mipmap), but I'm still reliably encountering a crash. I assume the issue is still most likely an ATI-related issued, just wanted to make sure you're aware of it with 2015. I'll try it on another machine with an alternative card if I can....
timrobinson
New Contributor III
Hi - tested on another machine, definitely an ATI related issue. New hardware on order....
Thanks for the help.
ThomasFuchs
Hi Tim,
Sorry to hear you had to change your hardware.
The CityEngine team is committed to support ATI hardware. So it would be very helpful to us, to get the scene, that creates the crash on opening.
