Domains on subtypes known issue
2546
12-08-2015 08:20 AM
Neil_TUGBatchelor
In relation to the following bug/known issue:
43880 - Unable to view domains for a feature layer enabled with coded value domains in a web map
Is there a resolution upcoming for this problem?  This is getting to be a bigger deal and it's been outstanding for a year.  It's not just in web maps.  It shows up when consuming the server rest endpoint directly in another application such as Geocortex or ArcFM for Silverlight.  Thanks to Patrick Demer​ for pointing me to this known issue in the first place.
ArcGIS for Server​, ArcGIS Online
MikeMillerGIS
Esri Frequent Contributor
There is a trick to make this work, you need to publish the layers rendered by the subtype.  This writes the domains per field into the renderer and most apps pick this up.
EGDB based feature services include a rest end point, querydataelement, that provides the class info.  I believe ArcGIS Pro is the only client reads that.
Hosted feature services do not have this.  If they did, clients could be updated to uniformly read this and the renderer would not matter.
I have a post in here that details this, will try to find it.
