I am trying to render a layer within ArcGISDynamicMapServiceLayer as per this API: ArcGISDynamicMapServiceLayer | API Reference | ArcGIS API for JavaScript
This code is not working.
//Rendering the parcels symbology to black var parcelSymbol = new SimpleFillSymbol().setStyle(SimpleFillSymbol.STYLE_NULL); parcelSymbol.outline.setStyle(SimpleLineSymbol.STYLE_SOLID); parcelSymbol.outline.setWidth(1); parcelSymbol.outline.setColor(new Color([0, 0, 0])); var dynamicData = new ArcGISDynamicMapServiceLayer(".../MapServer"); var newrenderer = new SimpleRenderer(parcelSymbol); var optionsArray = []; var drawingOptions = new esri.layers.LayerDrawingOptions(); drawingOptions.renderer = newrenderer; optionsArray[1] = drawingOptions; dynamicData.setLayerDrawingOptions(optionsArray); map.addLayer(dynamicData);
Solved! Go to Solution.
You need to enable support for dynamic layer on the map service in ArcGIS Server. Has it been enabled?
Thank you, this fixed one service that I host myself, but not for the other one hosted by a different party. I am assuming this option is not enabled. I guess I have to find a work around for this one! Any suggestions please?
