Search and Default Editor
4878
22
12-04-2015 08:36 AM
RickeyFight
MVP Regular Contributor
I am getting a weird result when I search for a location.
I have the Editor widget  and Search basic combined.
When I search for a location, I can zoom to it. Then when I click on any other point to edit it, I get this result:
Has anyone dealt with this?
i think I am looking for a way to clear search when I click anywhere not the search point.
Even when I clear the search bar I still cannot click on a point to edit:
RickeyFight
Robert!
I figured out a way around it!!!!!
      var search = new Search({
        map: map,
  enableButtonMode: true,
  enableInfoWindow: false,
  enableHighlight: false,
  enableLabel: false
      }, "search");
      search.startup();
I stopped the Infowindow from opening which is why it was not working in the first place.
Since I answered the question I will make mine as correct but thank you so much for the help through this process!
RobertScheitlin__GISP
Rickey,
   This is a known feature with the API and you have to re-initialize the editor widget to overwrite the changes to the popup made by the search widget. I have seen a couple of threads on this but I don't have the links off hand.
RickeyFight
Robert,
Thank you I will search harder for them
RickeyFight
I have searched for an example for a few hours and cannot find any.
Here is the thread with the advice from Kelly:
Bug? Editor Widget & Search Widget not playing nice together
Rickey,
   Did the link I provided answer your question?
RickeyFight
Robert,
Sort of,  I got the search to clear, but I cannot get the editor to reinitialize.
I am still working with the code.
RickeyFight
Robert,
I am getting hung up on the destroyEditor part.
                map: map
            }, "search");
            search.startup();
            search.on("select-result", lang.hitch(this, function () {
                //if edit tool is enabled we'll have to delete/create
                //so info window behaves correctly.
                on.once(this.map.infoWindow, "hide", lang.hitch(this, function () {
                    search.clearGraphics();
                    console.log("Cleared Search Graphics");
                       _destroyEditor();
                        console.log("Test");
                       initEditing();
             function _destroyEditor() {
                   if (this.editor) {
                        this.editor.destroy();
  console.log("Destroyed editor");
                        this.editor = null;
            function initEditing(event) {
                var featureLayerInfos = arrayUtils.map(event.layers, function (layer) {
                    return {
                        "featureLayer": layer.layer,
                        "isEditable": true,
                        'showAttachments': true,
                        "showDeleteButton": false,
                        "fieldInfos": [{
                            'fieldName': 'Caller_Name',
                            'isEditable': false,
                            'tooltip': 'Caller Name',
                            'label': 'Caller Name:'
                            'fieldName': 'Priority',
                            'isEditable': true,
                            'tooltip': 'Priority',
                            'label': 'Priority:'
                            'fieldName': 'Location',
                            'label': 'Location:'
                            'fieldName': 'Phone',
                            'label': 'Phone:'
                            'fieldName': 'Notes',
                            'isEditable': true,
                            'label': 'Notes:'
                            'fieldName': 'CallType',
                            'isEditable': true,
                            'label': 'CallType:'
                var settings = {
                    map: map,
                    layerInfos: featureLayerInfos
                var params = {
                    settings: settings
                var editorWidget = new Editor(params, 'editorDiv');
                editorWidget.startup();
                //snapping defaults to Cmd key in Mac & Ctrl in PC.
                //specify "snapKey" option only if you want a different key combination for snapping
                map.enableSnapping();
Rickey,
   You are creating a local var for your editor when you init your editor and the example Kelly is using creates a global var for the editor called this.editor
RickeyFight
Robert,
I mostly realize what is happening, I just am not 100% sure how to fix it.
What is happening now is that when the editor tries to reinitialize I get this error:
Uncaught TypeError: Cannot read property 'layers' of undefined
I realize that this:
is a local variable but I am unsure how to make it global.
