incompatibility between ESRI Android SDK and Google Play Services
3428
12-01-2015 05:35 AM
tawfiqdawod
There is the Execution error when I combine the ArcGis SDK in android in android studio ADT, there is the error:
Error:Execution failed for task ':app:dexDebug'.
> com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command 'C:\Program Files\Java\jdk1.8.0_66\bin\java.exe'' finished with non-zero exit value 1
when I combine it with existing google play services in the project.
this is the build.gradle app file:
apply plugin: 'com.android.application'
android {
  compileSdkVersion 'Google Inc.:Google APIs:23'
   buildToolsVersion '23.0.2'
   defaultConfig {
  applicationId "com.eywa.paltrack"
   minSdkVersion 16
   targetSdkVersion 23
   versionCode 1
   versionName "1.0"
   multiDexEnabled true
  buildTypes {
  release {
  minifyEnabled false
   proguardFiles getDefaultProguardFile('proguard-android.txt'), 'proguard-rules.pro'
  packagingOptions {
  exclude 'META-INF/LGPL2.1'
   exclude 'META-INF/LICENSE'
   exclude 'META-INF/NOTICE'
dependencies {
  compile fileTree(include: ['*.jar'], dir: 'libs')
  testCompile 'junit:junit:4.12'
   compile 'com.android.support:appcompat-v7:23.1.1'
   compile 'com.android.support:design:23.1.1'
   compile 'com.google.android.gms:play-services:8.3.0'
when I remove ArcGis Sdk library from my Project the project executed successfully.
AlexanderNohe1
Occasional Contributor III
I believe that you are missing a compile in your dependencies here.  My dependencies have this line in it:
compile 'com.esri.arcgis.android:arcgis-android:10.2.7'
