AnsweredAssumed Answered
RasterConditionalOpClass does not work in arcgis 10.2 but works in 10.0
Question asked by monir_mostafizur1 on Nov 30, 2015
I want to do DEM Reconditioning. For this purpose I have used DEM and stream. I do several operations on DEM and stream.
I am using .NET in arcGIS 10.2
# From stream , I made streamRaster with  ....conversionOp.ToRasterDataset((IGeoDataset)feaureClass, "GRID", workspace, string_RasterName);...
# Then  I do .... >>>>  logicalOp.IsNull((IGeoDataset)streamRaster); >>> mathOp.Minus(rawDEMGeo, smoothDropGeo);>>>conditionalOp.SetNull(conditionGeo, smoothDropFromDEMGeo);
and so on...
All this works fine If the input DEM is outside a gdb. But when The input DEM is inside a gdb, when I am going to do >>conditionalOp.SetNull(conditionGeo, smoothDropFromDEMGeo)<< this operation, an exception throws and it says an temp raster like (g_g123) can not open.
In arcGIS 10.0 , DEMReconditioning works well for both inside gdb  DEM and outside gdb  DEM.
arcgis 10.0 and 10.2 any differences ?? Or how I can I overcome this .....
IRasterDataset streamRasterDataset = rasterFromFc.CreateRasterFromFc(_agreeStreamFC,_rawDEMRaster, "D:\\W", 10000);
            IRaster streamRaster = streamRasterDataset.CreateDefaultRaster();
             IConversionOp conversionOp = new RasterConversionOpClass() {
                 OutWorkspace = rasterFromFc.WorkSpace
             IRasterMakerOp rasterMakerOp = new RasterMakerOpClass() {
             ILogicalOp logicalOp = (ILogicalOp)new RasterMathOps() {
             IMathOp mathOp = (IMathOp)new RasterMathOps() {
             IConditionalOp conditionalOp = new RasterConditionalOpClass() {
             IDistanceOp distanceOp = new RasterDistanceOpClass() {
            Console.WriteLine("Making buffer constant grid ..");
            IGeoDataset bufferGeo = rasterMakerOp.MakeConstant(bufferDist, false);
            Console.WriteLine("Making smooth constant grid ..");
            IGeoDataset smoothDropGeo = rasterMakerOp.MakeConstant(smoothDrop, false);
            Console.WriteLine("Making sharp constant grid ..");
            IGeoDataset sharpDropGeo = rasterMakerOp.MakeConstant(sharpDrop, false);
            IGeoDataset conditionGeo = logicalOp.IsNull((IGeoDataset)streamRaster);
            IGeoDataset smoothDropFromDEMGeo = mathOp.Minus(rawDEMGeo, smoothDropGeo);
            Console.WriteLine("Computing smooth drop/raise grid ..");
            IGeoDataset smoothGeo = conditionalOp.SetNull(conditionGeo, smoothDropFromDEMGeo);//  in ArcGis 10.2 , exception here
            Console.WriteLine("Computing vector distance grid ..");
            object obj = null;
            object obj2 = null;
            IGeoDataset vectorEucDistGeo = distanceOp.EucDistance(smoothGeo, ref obj, ref obj2);
            smoothGeo = mathOp.Int(smoothGeo);
Outcomes
