Obtain the identitity value from an insert
2677
11-30-2015 03:03 AM
FabianoFerrazza1
Hi all,
i need insert a row in a not SDE table and retrieve the identity id.
In sql is quite simple:
INSERT INTO TAB1 (val1,val2,val3) OUTPUT INSERTED.IDVALUES (0,1,2).
I can't use a direct SQL connection, i must use arcobjects.
The ISqlWorkspace.ExecuteSQL is ususable, because is void.
The dbms is SQLServer 2008 R2
Could you help me?
Fabiano
Tags (1)
