JS-API: featureLayer.selectFeatures
3699
11-30-2015 05:43 AM
ChrisPag
is there any posibility to select only the Features located inside the Selection-Geometry?
The Method featureLayer.selectFeatures(query,FeatureLayer.SELECTION_NEW) as well takes
the Features intersecting the shape of the Selection-Geometry
Chris
KenBuja
MVP Esteemed Contributor
You're correct. That should have been SPATIAL_REL_CONTAINS
KenBuja
You can set the spatialRelationship method of the Query task. By default, it's SPATIAL_REL_INTERSECTS, but you can set it to SPATIAL_REL_WITHIN.
ChrisPag
    thank you for the response. Your Suggestion works in the wrong direction.
    I want to select all PolygonFeatures from FLayer located completly in
    a handdrawn Polygon called geo.
    SPATIAL_REL_WITHIN gives a result if geo is complete located in one Feature
    of FLayer.
function clipFLayer(geo) {
  var selectionQuery = new esri.tasks.Query();
  selectionQuery.spatialRelationship = esri.tasks.Query.SPATIAL_REL_WITHIN;
  selectionQuery.geometry = geo;
  FLayer = new esri.layers.FeatureLayer(theService, {outFields: ["*"]});
  FLayer.selectFeatures(selectionQuery,esri.layers.FeatureLayer.SELECTION_NEW);
  FLayer.on("selection-complete", findRelatedRecords);
KenBuja
ChrisPag
Thank you!
