AnsweredAssumed Answered
Mosaic Data Set, Statistics, Histograms and Color Balancing
Question asked by Ateles on Nov 25, 2015
Hello everyone in and outside of the ESRI team,
I am working on the creation of a mosaic of Landsat imagery aiming for an outcome as uniform as possible.
I have preprocessed the Landsat reflectance images with Fmask.
I then calculated NoData areas and converted the images to 16bit unsigned with the copy raster tool.
There after I have transformed the projection of the images to be uniform with the project raster tool.
I then saved these images in a geodatabase in ArcMap 10.3.
I ran the tool calculate statistics an all images.
I then imported the images into a new Mosaic Dataset. The function I used was stretch set to StDev.
With the define Mosaic NoData tool I set 0 to be NoData.
If I know want to color balance the mosaic using any other setting than the default color balancing fails.
The output is:
Failed to put local stats raster to color correction table. The object ID is 1
The system cannot locate the object specified.
Failed to execute (ColorBalanceMosaicDataset).
If I analyze the MDS for the stats I receive the following Warning:
The top-level raster function associated with the mosaic dataset item does not have histogram and statistics.
Looking at the Table of the MDS and the Properties of OBJECT ID 1 Stats for each band are present.
I greatly appreciate any help on this issue!!!!
Outcomes
