Change Labels when Scale Changes
3137
11-24-2015 01:10 PM
HaniDraidi
Occasional Contributor II
Is there a way to change the label expression based on the scale (for the same layer)?
For example, when the scale is between 1:1 and 1:10,000 the features are labeled with [field_1], and when the scale is between 1:10,000 and 1:50,000 the features are labeled with [field_2].
Any help is highly appreciated,
Hani
WesMiller
Regular Contributor III
In your layer properties dialog you can "Define classes of features and label each class differently" and set "Scale Range..." for each label class.
WesMiller
HaniDraidi
Many Thanks Wes,
I tried this and it worked well!
JayantaPoddar
MVP Esteemed Contributor
One workaround is to create two different feature-linked geodatabase annotation classes, and defining the scale range in each one of them.
Think Location
