Cannot install ArcGIS Pro
7006
7
11-24-2015 08:07 PM
RogerWilson
I'm running Windows 7 Ultimate on a Windows partition on a MacBook Pro.  The processor is: Intel Core i7-2820QM CPU @ 2.3GHz
I'm able to download the installation file from the ESRI, extract the CAB file, and get to the point where it says "Installation files successfully extracted."  When I click on "Close" (which should launch the setup program), I get the following error:
"This installation package is not supported by this processor type. Contact your product vendor."
I was able to install ArcGIS Desktop with this same exact hardware setup with no problem, so this error is perplexing.  Thoughts or help would be greatly appreciate!
Editorial rant: Obviously, ESRI wants us Mac users to seek out Open Source solutions that run on Macs since they don't have a Mac version and seem to do nothing to play well with Mac.  (I already had to shell out $80 for Parallels just to easily switch between Mac and Windows.)  I've played around with QGIS (open source, runs on Mac, etc.), so that might be a longer term solution.  But, for now, I need ArcGIS Pro for a course I'm taking...
DanPatterson_Retired
This link is pretty useful for those contemplating installing or needing Pro
ArcGIS Pro system requirements—ArcGIS Pro | ArcGIS for Desktop  and there is this neat link which allows you to
pre-test before installing.... Nice touch, saves some grief
Can You Run It?
Perhaps these links should be on the main page.  If you aren't on the list, you can't.  Distribute to your classmates.
Can You Run It?
JeremyWright
FYI: That message means that it's a 32-bit OS.
ArcGIS Pro requires a 64-bit host OS (the virtual "windows" you're installing on) to install and run.
For educational users we have a collection of resources specifically about running ArcGIS on Mac and iOS platforms:  Macintosh & iOS Support - EdCommunity - Esri
TimMinter
Occasional Contributor III
Thanks Jeremy, good info.
I never thought to myself, "Self... the Mac is Ed."  Not sure why this info didn't float up high when asking Google questions about ArcGIS on OS X with Fusion and/or Bootcamp.
KateRose
New Contributor III
It would be great to know where this guidance has moved to
KateRose
New Contributor III
JeremyWright
Kate,
current info on running ArcGIS Pro on a Mac is available at Run ArcGIS Pro on a Mac—ArcGIS Pro | Documentation
Regards,
Jeremy W.
KateRose
New Contributor III
Thanks! I found it but am wondering if there's a forum about this also. I'm not sure if I meet the hardware requirements. I have a macbook pro but with a 2.3 GHz Dual Core i5 processor and 16GB RAM.
