Refused to display <<URL>>in a frame because it set 'X-Frame-Options' to 'SAMEORIGIN'.
5991
11-22-2015 08:01 AM
ABHISHEKSINDAL1
While embedding code in StoryMap Journal template, taken from CityEngine viewer, getting following error. Where do we need to make changes? IIS manager or in embedding code? and what changes?
Error: Refused to display <<URL>>in a frame because it set 'X-Frame-Options' to 'SAMEORIGIN'.
Please suggest.
GregoryL_Azou
Occasional Contributor III
Are you using Portal for ArcGIS?
In ArcGIS Online it seems to works for me, see this Journal http://www.arcgis.com/apps/MapJournal/?appid=01c40e1ac2924c33a663c8731f80595e that embed this scene http://www.arcgis.com/apps/CEWebViewer/viewer.html?3dWebScene=2e71f229901a401c9a73560975a144e7
If you are on Portal, it must be that the Portal is configured to not allow a scene to be embedded in application. That would be a setting to change at the web server level. I suggest that you contact Esri technical support Esri Support
ABHISHEKSINDAL1
We are also using AGOL Org acc. Thanks for your help.
GeorgeVernardos
New Contributor III
I have a scene in Portal for ArcGIS, and need to publish it through an iframe at a site with different domain, so I am stuck in the situation described above. I tried to tweak iis, no luck...
If anyone has done this, please enlighten the rest of us.
StephenSylvia
Is your web scene shared public? If you are attempting to embed any ArcGIS online/portal templates or web scenes, they must be shared publicly. If they are private or shared only with and org/group, the applications will first redirect to a login page. For security reasons, this login page is not allowed to be embedded.
