Portal Request Error under Layers
3073
11-18-2015 09:39 AM
MichaelAugust
Occasional Contributor III
I get this "RequestError" below under Layers instead of the Layer URL, but if I click on it the service appears and I can c/p REST endpoint, wondering if anyone has the same issue? Or has resolved it? Thanks!
DerekLaw
Esri Esteemed Contributor
Hi Michael,
  • The screen capture looks like the Item Details page for a hosted feature service in Portal, is that right?
  • Did the hosted feature service publish correctly and without any issues?
  • Can you open and view the hosted feature service in the Portal map viewer?
  • What release of Portal for ArcGIS are you using?
  • What authentication option did you set for Portal?
  • Did you configure your hosting server correctly?
Hope this helps,
