Batch Processing - Composite Images
3165
11-17-2015 02:39 AM
ZiaAhmed
New Contributor III
I am processing  190s HDF files  from a Folder (J:\RapidEyr_Atcor\HDF).  Here is the example of file name  in the HDF Folder:
AtmosCorrected_4549227_2014-12-23_RE1_3A_278182.hdf
AtmosCorrected_4549227_2015-02-15_RE1_3A_278163.hdf
AtmosCorrected_4549227_2015-01-13_RE1_3A_278182.hdf
AtmosCorrected_4549227_2015-03-23_RE1_3A_278102.hdf
Each HDF  file contains 13 bands. But I want to extract first  5 bands and convert to TIFF files  and  save them in a folder. Since 1 have 190 HDF files,  I want to create 190 folders in J:\RapidEyr_Atcor\TIFF . Folder name should be like this:
J:\RapidEyr_Atcor\TIF \4549227_2014-12-23_RE1_3A_278182,
J:\RapidEyr_Atcor\TIF \4549227_2015-02-15_RE1_3A_278163
J:\RapidEyr_Atcor\TIF \4549227_2015-01-13_RE1_3A_278182
J:\RapidEyr_Atcor\TIF \4549227_2015-03-23_RE1_3A_278102
Each folder will be contained 5 tiff files. The file names would be
4549227_2015-02-15_RE1_3A_278163_b1. tif,
4549227_2015-02-15_RE1_3A_278163_b2.tif,
4549227_2015-02-15_RE1_3A_278163_b3.tif,
4549227_2015-02-15_RE1_3A_278163_b4.tif,
4549227_2015-02-15_RE1_3A_278163_b5.tif
Following in ArcPython Script works fine when input HDF files already have been in different sub folders according to the date and tiles.  But I have problem to define Folder names and files  names in the folder. If someone help me out, then it will be save me a lot of time.
Zia
import arcpy
try:
 arcpy.env.workspace = r"J:\RapidEyr_Atcor\HDF"
 rasterListA = arcpy.ListRasters()
 for raster in rasterListA:
 tifOutA=" M:\\TIF\\"+raster[15:40]
 arcpy.ExtractSubDataset_management(raster,tifOutA+"_B1"+".tif", "0")
 arcpy.ExtractSubDataset_management(raster,tifOutA+"_B2"+".tif", "1")
 arcpy.ExtractSubDataset_management(raster,tifOutA+"_B3"+".tif", "2")
 arcpy.ExtractSubDataset_management(raster,tifOutA+"_B4"+".tif", "3")
 arcpy.ExtractSubDataset_management(raster,tifOutA+"_B5"+".tif", "4")
except:
 print "Extract Subdataset example failed."
 print arcpy.GetMessages()
Tags (1)
DanPatterson_Retired
could you format your code using one of the methods here Code Formatting... the basics++
your indentation is either incorrect or it didn't get carried over during the copy-paste
