AnsweredAssumed Answered
Export Web Map Task: Failed to create layer from service
Question asked by shoe788 on Nov 13, 2015
Latest reply on Jan 7, 2016 by kousikm
I'm using Arcgis server 10.3 and am having trouble using Print | API Reference | ArcGIS API for JavaScript
Some of my services are secured via tokens and I get access to my rest service directory through my webserver proxy. I am able to print unsecured services fine. Any secured services however return the error:
Unable to complete operation.
Error executing tool.: Layer "xx": Failed to create layer from service at http.../MapServer/xx. Failed to execute (Export Web Map). Failed to execute (Export Web Map Task).
If I directly copy the webmap JSON into the export task and run it this error also appears, leading me to believe this is a problem on the arcgis server side.
I found this relevant thread (Printing Secured Servies with Export web map task ) which seems to be my issue, but there is no apparent solution from there.
Outcomes
