Hello
I'm trying to incorporate an ExtractData service on arcgis server 10.3. As per HERE to use in apps.
If I understand it correctly, in order to extract data using the esri hosted ExtractData service you must also use hosted feature services to enable extraction. I have already implemented a geoprocessing tool that will extract data using the older clip and ship server tool, but I'm hoping to find a solution that can be used across several apps without several unique geoprocessing tools.
Has anyone installed this ExtractData analysis service on Server or used the ExtractData the class form the javascript api?
George
