SR locak on gdb is not releasing in SOE
2364
11-09-2015 08:04 PM
HaiderAli
My problem is sr lock is not releasing on gdb , also please see that code can be improved?
Below is my code
    public String exportGDB(String whereClause,IServerObjectHelper serverObjectHelper)  // returns the path of GDB
    String tempPath = System.getProperty("java.io.tmpdir");
    SOEHelper soeHelper = new SOEHelper();
    String fileName = System.currentTimeMillis() + ".gdb";
    try
    // Create a FileGDB workspace factory
    IWorkspaceFactory workspaceFactory = new FileGDBWorkspaceFactory();
    // Create a new File geodatabase
    IWorkspaceName workspaceName = workspaceFactory.create(tempPath,fileName , null, 0);
    IName wsName = (IName) workspaceName;
    IWorkspace workspace = new IWorkspaceProxy(wsName.open());
    IFeatureWorkspace featureWorkspace = new IFeatureWorkspaceProxy(workspace);
    IMapLayerInfos layerInfos = soeHelper.getLayerInfo(serverObjectHelper);
    IQueryFilter qf = new QueryFilter();
    qf.setWhereClause(whereClause);
    IFeatureClass fc = null;
    IMapLayerInfo layerInfo = null;
    IFeatureClass gdbFeatureClass = null;
    IFeature newFeature = null;
    IFeature feature = null;
    IFeatureCursor  featureCursor = null;
    for (int i=0; i < layerInfos.getCount(); i++)
    layerInfo = layerInfos.getElement(i);
    fc = soeHelper.getFeatureClass(layerInfo.getID(), serverObjectHelper);
    // IWorkspaceName fcwsName = (IWorkspaceName)fc.getFeatureDataset().getWorkspace();
    IFeatureClassDescription fcDesc = new FeatureClassDescription();
    IObjectClassDescription ocDesc = (IObjectClassDescription) fcDesc;
    gdbFeatureClass = new FeatureClass(featureWorkspace.createFeatureClass(layerInfo.getName(), layerInfo.getFields(),
    ocDesc.getInstanceCLSID(), ocDesc.getClassExtensionCLSID(), esriFeatureType.esriFTSimple, "SHAPE", ""));
    // IFeatureClassName sourceFeatureClassName = new FeatureClassName();
    // IFeatureDataConverter2 featureDataConverter = new FeatureDataConverter();
    // IEnumInvalidObject enumInvalidObject = featureDataConverter.convertFeatureClass((IDatasetName)fcwsName,
    // qf, null,(IFeatureDatasetName)workspaceName, sourceFeatureClassName,
    // soeHelper.getGeomRef(fc),
    // layerInfo.getFields(), "", 1000, 0);
    // // Check for errors.
    // IInvalidObjectInfo invalidObjectInfo = null;
    // enumInvalidObject.reset();
    // while ((invalidObjectInfo = enumInvalidObject.next()) != null){
    // // Handle the errors in a way appropriate to the application.
    // System.out.println("Errors occurred for the following feature: " +
    // invalidObjectInfo.getInvalidObjectID());
    featureCursor = fc.search(qf, true);
    feature =  featureCursor.nextFeature();
    while(feature != null)
    newFeature = gdbFeatureClass.createFeature();
    for (int j = 0; j < featureCursor.getFields().getFieldCount(); j++)
    if(featureCursor.getFields().getField(j).getType() ==  esriFieldType.esriFieldTypeOID)
    { // skip
    continue;
    newFeature.setValue(newFeature.getFields().findField(featureCursor.getFields().getField(j).getName()), feature.getValue(j));
    newFeature.store();
    Cleaner.release(newFeature);
    Cleaner.release(gdbFeatureClass);
    Cleaner.release(featureCursor);
    // Cleaner.releaseAllInCurrentThread();
    // Cleaner.release(gdbFeatureClass);
    // Cleaner.release(featureCursor);
    soeHelper.releaseSilently(workspaceName);
    soeHelper.releaseSilently(wsName);
    soeHelper.releaseSilently(layerInfos);
    Cleaner.release(featureWorkspace);
    Cleaner.release(workspace);
    Cleaner.release(workspaceFactory);
    qf = null;
    workspace = null;
    featureWorkspace = null;
    workspaceFactory = null;
    fc = null;
    layerInfo = null;
    newFeature = null;
    feature = null;
    return fileName;
    } catch (Exception e) {
    e.printStackTrace();
    return null;
Tags (3)
