Prospectivity maps (Geoscience data)
5107
11-09-2015 07:51 AM
SamanTavakoli
I am a geophysicist and I am going to create a prospectivity map.
In other words, I've got several geophysical maps (e.g. magnetic anomaly, Bouguer anomaly etc.) and I would like to pick up the values for some interesting areas (e.g. magnetic anomaly weight 2/5, Bouguer anomaly weight 4/5....), assign weight to them and tell the program to find other areas in the map with similar values. Does any one know how may I do this?
Best regards,
/Saman
MitchHolley1
MVP Regular Contributor
Take a look at ArcGIS Help 10.1- Hotspot Analysis
Let me know what you think.
MitchHolley1
SamanTavakoli
Dear Mitch,
Many thanks for your answer. What I am still missing is the way to do it. For someone who has not been working with GIS processing tools for many years, applying the hot spot would be impossible unless a very clear step by step guidance is provided.
Is there any link or description for a beginner about how to do it?
/Saman
MitchHolley1
Check out these tutorials:
Tutorial 9-2: Performing hot-spot analysis - YouTube
How to perform Cluster and hotspot analysis?!
Hot Spot Analysis - Part 1 | ArcGIS Video
Let me know if you need anymore help.  Those links should run you step-by-step instructions on how to do it.
