Ops Dashboard redraw issues
2782
11-06-2015 07:19 AM
CorySchinkel
I have a dual monitor + laptop setup.  The 2 monitors are Dell model U2414H.  When I display Ops Dashboard on either of the monitors, I get really bad redraw problems.  However, on the laptop display there are no issues.  I'd really like to be able to take advantage of the real estate of my dual monitors, but it's just too difficult to get anything done with the redraw issue.  I do not have this issue with any other applications, just Ops Dashboard.  Does anyone have any suggestions for fixing this?
This is an example of the redraw issue.  This is after maximizing ops dashboard.  The map widget expands, but the application window does not.  If I open a different application that covers Ops Dashboard, then minimize the second application, then Ops Dashboard redraws correctly.
ChristopherOlsen
Occasional Contributor III
HI, I'm not sure if you're still having this problem, but this article may help address the redraw issues:
Problem: Unable to load custom extensions after installing and launching Operations Dashboard for Ar...
