Searching field with upper or lower case
3991
6
11-05-2015 09:15 AM
CCWeedcontrol
Occasional Contributor III
I have a script that works good but only if the first letter of the input has the first letter upper case.
Currently every road name starts with an upper case letter. How can I format the expression to allow for either upper or lower case inputs.
Thanks.
import arcpy
arcpy.AddMessage("Starting")
pu = arcpy.GetParameterAsText(0)
arcpy.AddMessage(pu)
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
lyr = arcpy.mapping.ListLayers(mxd, "Roads", df)[0]
arcpy.AddMessage(lyr.name)
expression = "FENAME LIKE '%{}%'".format(pu)
arcpy.AddMessage(expression)
arcpy.SelectLayerByAttribute_management(lyr,"NEW_SELECTION",expression)
df.extent = lyr.getSelectedExtent()
arcpy.RefreshActiveView()
arcpy.AddMessage("Completed")
DarrenWiens2
MVP Honored Contributor
It looks like ArcGIS SQL uses UPPER() rather than UCASE().
Try:
UPPER(FENAME) LIKE '%{}%'".format(pu.upper())
DarrenWiens2
Force both sides to uppercase, then compare (untested):
expression = "UCASE(FENAME) LIKE '%{}%'".format(pu.upper())
If pu = 'elm street', it would be turned to 'ELM STREET'. It would then match capitalized versions of records like 'Elm Street', 'ELM Street', 'eLm StReEt', etc., all of which would be treated like 'ELM STREET'.
CCWeedcontrol
thanks for the reply.
getting error on expression = "UCASE(FENAME)LIKE '%{}%'".format(pu.upper())
  File "C:\GIS\Python Scripts\ZoomTo\ZoomToRoad.py", line 13, in <module>
  File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\management.py", line 6688, in SelectLayerByAttribute
    raise e
ExecuteError: ERROR 000358: Invalid expression
DarrenWiens2
Try:
CCWeedcontrol
does the UPPER() only for the first word or for more then one word?
The feature class attributes are like the following Desert Hills Road,Desert Wolf Lane etc.
CCWeedcontrol
Looks like it does. Thanks.
DarrenWiens2
UPPER() applies to the entire string within the parentheses: e.g. UPPER('Desert Hills') = 'DESERT HILLS'
