AnsweredAssumed Answered
Exporting table to sde
Question asked by nigel_ngl2 on Nov 4, 2015
Latest reply on Dec 8, 2015 by nigel_ngl2
HI, My objective is to export a featureclass to sde.
My code is as follows:
  IPropertySet propertySet = new PropertySetClass();
            propertySet.SetProperty("SERVER", "3019-h2-xyz");
            propertySet.SetProperty("INSTANCE", "SDE:SQLSERVER:TEMP-INS-COM");
            propertySet.SetProperty("DATABASE", "foo");
            propertySet.SetProperty("AUTHENTICATION_MODE", "OSA");
            propertySet.SetProperty("VERSION", "dbo.DEFAULT");
            IWorkspaceFactory workspaceFactory = new SdeWorkspaceFactoryClass();
            IFeatureWorkspace pArcSDEFeatureWorksapce = workspaceFactory.Open(propertySet, 0)  as IFeatureWorspace
      IWorkspace2 pWS2 = pArcSDEFeatureWorksapce as IWorkspace2;
                if (pWS2.get_NameExists(esriDatasetType.esriDTTable, intersect_featurename))
                    IDataset pExistingDataset = pArcSDEFeatureWorksapce.OpenTable(intersect_featurename) as IDataset;
                    if (pExistingDataset.CanDelete())
                        pExistingDataset.Delete();
              Geoprocessor pGp = new Geoprocessor();
                DisplayMessage("Exporting to SDE....");
                TableToGeodatabase pTableToGeodatabase = new TableToGeodatabase();
                pTableToGeodatabase.Input_Table = intersectOutputFeatureClass.AliasName;
                pTableToGeodatabase.Output_Geodatabase = pArcSDEFeatureWorksapce;
                pGp.Execute(pTableToGeodatabase, null);
The pArcSDEFeatureWorksapce allows me to retrieve and delete any feautureclasses. Also if I connect to this database connection in  arccatalog and then run this code it exports a featureclass to sde. But if the connection in arc-catalog is disconnected the execution fails. If I am connecting to an arcsde workspace programmatically then why do I have to connect to an existing connection and then execute the tool?
Also this connection works fine in model builder without having me connect a connection in catalog.
Regards,
Nigel.
Outcomes
