I have worked with such languages as Python when dealing with ESRI geometries.
However, I have now been asked to amend some C# to add a group of simple line geometries (straight lines) to a map, sourced from a soatial SQL table. We only seem to have ArcGIS Client available and I don't know where to start.
I will try and explain the issue as carefully as I can.
We have a SQL Server spatial table called DP_Accesses that, in simple terms, has a unique key and a geometry of LineString e.g.
APID - char(18)
Shape - geometry of LineString
This is itself a huge table with about 30 million rows
I have managed to build a list of APID values in C# that I want to use to select rows from this table and add to my map. However, please note that this could be a list of anything from 1 to about 7000 APID values, so in itself it is not a small list
As I am at a point where I have completed this list of APID values, how do I create the layer/spatial collection that can be added to the map, using the ARCGIS Client functionality in C#? I am on .Net Framework 4 and using ARCGIS 10.2 Client.
Cheers
Mark
