AnsweredAssumed Answered
Export multiple maps based on layer field values
Question asked by fraidknot on Oct 20, 2015
Latest reply on Oct 20, 2015 by wwmiller68
I am trying to find a solution that will allow me to export multiple pdf maps based on a layer's multiple values in a single field while keeping the map view or extent static.  In times past, I always would split the layer field value by attribute, manually symbolize the multiple layers generated and export each map by turning each layer on and exporting the result.  This worked fine until now where I have a layer that has approx 45 different values and a single map is required for each value.
Outcomes
