Latitude and Longitude Coordinates in Wrong Hemisphere
5576
7
10-20-2015 08:32 AM
MorganCunningham
This is my first time using ArcMap (10.1) for a project and I'm having some trouble! I am trying to plot points off the coast of the Northeast Atlantic Coast, and they are ending up off the coast of Ghana. I've tried importing from a csv file and an excel spreadsheet. I attached a sample of my data.
I know the western hemisphere longitude values must be negative and northern latitude values must be positive. Any other reason why I am not plotting these points correctly?
NeilAyres
Are you correctly defining which is X and Y.
Longitude = X; Latitude = Y
MorganCunningham
Yes I am, when I plotted the exported data I put the longitude as X and latitude as Y.
GabrielUpchurch1
Occasional Contributor III
Are you specifying a coordinate system?  You should probably be using GCS_WGS_1984.  I tested with your data and it worked correctly.  If you are not sure what I mean, just ask.
MorganCunningham
Okay! How do you specify a coordinate system? Do you specify when you plot the data?
GabrielUpchurch1
What procedure are you using to plot the data?  Here is what I did:
1. Add spreadsheet to ArcMap.
2. Right-click on spreadsheet name and select "Display XY Data."
3. "Edit" coordinate system section and select GCS_WGS_1984.
MorganCunningham
Figured out how to edit the coordinate system...thank you so much! I figured it had to be something pretty simple
SimonKettle
