Update M Values of routes
3700
10-19-2015 08:40 AM
PV
New Contributor III
Hello
I created routes with the "Create Routes Tool" in ArcGIS 10.2.2. The route persists of rivers for quite a large area. The flow direction of the rivers are either "1" which means flow direction in digitized direction or "2" = flor direction against digitized direction. This seems to be correct for all routes.
When I open the "Edit Sketch Properties" I see that the M-Value however is not correct for all routes with the value 1 = flow direction in digitized direction (pic with red highlighting).
I Need the M Value to be 0 at hashtag 0. The highest M Value should be at the highest hashtag hence the M Values should be switched (see pic with green higlighting).
When I flip the routes, I flip the  whole direction which I dont want as the direction is correct (blue highlighting).
I only Need the M-Values to flip, not the #-values. I can do this with right click on the route --> route measure editing --> set distance. However, this is only possible for one route at a time and as I have many routes I am looking for a solution to do this automatically. Is there an update m values tool or anything like this in ArcGIS? I could not find anything.
TedKowal
Occasional Contributor III
When I use "Create Route Tool", in order to do the Measures for the lines that are in reverse digitized directions, I use the two field options.  In other words I populate a to and from field with the min segment measure and max segment measure respectively.  This is on the source non PolylineM shape from which I am creating the routes.  Using another field to indicate which of the lines that are running counter to digitized direction, I swap the to from fields.  The result measure then is reversed in order of your drawn segments.
Hopefully this makes some sort of sense to your.  I do not work with stream but with roads.  I use a dual centerline drawn in the direction of car travel (analogous to stream flow), one side of my route is always in the opposite of the digitized direction.  So I was face with you issue of the opposite side of the road measure being incorrect similar to your examples.  To overcome this I used a min/max (to/from) to build my routes and swaping the min/max for all the segments going the opposite direction.
hope this helps.
DuncanHornby
MVP Notable Contributor
If you can use ArcObjects then the Interface you need to use is the IMSegmentation​, it has a method ReverseMsOrder which would do what you want.
If you are looking for a python solution you could try the following (but untested idea):
  • Create from the dataset where all polylines which are "1" the nodes with their M values
  • Flip the values for these pair of nodes
  • Use the Calibrate route tool using your flipped M points
If it were me I would use the IMsegmentation route but then I know how to program in VBA!
TedKowal
hope this helps.
PV
New Contributor III
Thank you Ted!
This solved my Problem exactly! I did exactly the same steps as you suggested and got what I was looking for!
