Story Map - shortlist failing to open
2439
10-19-2015 01:45 PM
ChayaBalsiger
I created a story map - shortlist that worked fine on Friday, but when I came into work on Monday to make some changes to it, it would not open.  The wheel just keeps spinning when I try to open the website.  Any help would be much appreciated.  The web map can be found here: http://maps.cityoftulsa.org/sandbox/shortlist/
RupertEssinger
Hi.
Looking at your web map:
http://www.arcgis.com/home/webmap/viewer.html?webmap=5c1119d3de844c51b1aac3fcf2e139a9
the most recent point added into the layer that defines all your points has a Tab_Name value ("Downtown Tulsa/Arkansas River") that is not present in the TAB_ORDER variable in your Index.html. TAB_ORDER expects all of the tab names used in your layer to be included.  So it just seems like you or someone else added to the data since Friday and either didn't add the correct value for the Tab_Name field or they've defined a new tab without it being reflected in the TAB_ORDER variable in your Index.html. So you just need to either update the Tab_Name for that new place to use one of the existing tab names, or add the new tab name into that variable, and it will work.
Your Shortlist data is OK apart from that. I can open your web map OK in our test Shortlist instance:
http://storymaps.esri.com/templates/shortlist/?webmap=5c1119d3de844c51b1aac3fcf2e139a9&DETAILS_PANEL...
(This test doesn't reflect the change to the tab order that you have defined in your Shortlist's Index.html file)
RupertEssinger
Hi.
ChayaBalsiger
That was it! Thank you so much!
