change basemapLayer in overviewMapDijit
2314
10-19-2015 07:59 AM
VincentChoffrut
hello everyone,
I'm trying to change the basemaplayer in a overviewmapDijit...
does anyone has a clue why the following code fragment doesn't work ?
THANX A LOT in advance!
var BM_OM = new ArcGISDynamicMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer",{
useMapImage: true
BM_OM.on("load", function(evt){
console.log('BM loaded');
var overviewMapDijit = new OverviewMap({
map: map,
baseLayer: 'BM_OM'
}, "overviewMapDiv");
overviewMapDijit.startup();
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi Vincent,
You are specifying the baseLayer as a string rather than the variable you defined previously.  You will also need to add the 'visible' option and set this to true.  Ex:
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>Overview Map</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
    </style>
    <script src="http://js.arcgis.com/3.14/"></script>
    <script>
      var map;
      require([
        "esri/map", "esri/dijit/OverviewMap", "esri/layers/ArcGISDynamicMapServiceLayer",
        "dojo/parser",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function (
        Map, OverviewMap, ArcGISDynamicMapServiceLayer,
        parser
        parser.parse();
        map = new Map("map", {
          basemap: "streets",
          center: [-122.445, 37.752],
          zoom: 14
            useMapImage: true
              map: map,
              baseLayer: BM_OM,
              visible: true
    </script>
  </head>
  <body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer"
         data-dojo-props="design:'headline', gutters:false"
         style="width: 100%; height: 100%; margin:0;">
      <div id="map"
           data-dojo-type="dijit/layout/ContentPane"
           data-dojo-props="region:'center'"
           style="padding:0">
      </div>
    </div>
  </body>
</html>
