qwerty@
Python Map Algebra error: Failed to execute (output)
Discussion created by qwerty@ on Jul 8, 2015
Latest reply on Oct 15, 2015 by curtvprice
Branched from an earlier discussion
Dear Jake,
I have a problem with another equation where I am using minimum and maximum value from my data. I am using the following code:
RI_tif = "C:\\output.tif"
# Process: Get Raster Properties
arcpy.GetRasterProperties_management(v6_tif, "MINIMUM", "")
# Process: Get Raster Properties (2)
arcpy.GetRasterProperties_management(v6_tif, "MAXIMUM", "")
# Process: Raster Calculator (3)
outSubt = (Raster("6.tif")-(float(Property))/((float(Property (2))-(float(Property))
outSubt.save("C:\\output_tif")
I have an error in the last line "Failed to execute (output)." I think that the problem is with the min, max values which I am using in the equation. Probably I implemented them in a wrong way. However, I could not find at ESRI website some example how to do this. Do you have maybe idea how to implement these values in python?
Thanks in advance.
Outcomes
