is there an option to add a point to a feature layer based on absolute x,y?
E.G. choose edit point and than place the point by entering the coordinates (e.g. in decimal degrees)
Felix
Felix
Hey Tim,
thanks for the comment. But I do not want to change an existing point. What I want to do is:
This doesn't seems to be rocket science, but I am not able to find such a solution...
Any ideas / samples?
Felix
Hey Felix,
This is not possible by just changing a X/Y field in the attribute table. In ArcGIS Desktop you could use the XY tool to get to the point and place a graphic and then place your point on the map.
In ArcGIS Online you can put x/y into the search box and it will get you there.
Hope this helps!
Tim
