Is it possible to edit a feature service form the ArcGIS desktop
2710
10-13-2015 04:11 AM
AhmadSALEH1
Occasional Contributor III
Is it possible to edit a feature service form the ArcGIS desktop ?
If yes how, If not Why we cannot do this at the level of desktop and we can do it at the level of the web mapping applications !!!
Regards,
Ahmad Saleh
Tags (1)
George_Thompson
Esri Frequent Contributor
Hi Ahmad,
Here is the information about editing a feature service from ArcGIS Desktop: About editing data from feature services—Help | ArcGIS for Desktop
Making a local copy of a feature service for editing—Help | ArcGIS for Desktop
Here some more information on editing feature services: Editor permissions for feature services—Documentation (10.3 and 10.3.1) | ArcGIS for Server
Hope this helps.
-George
--- George T.
George_Thompson
Hi Ahmad,
Hope this helps.
-George
--- George T.
JenniferMcCall4
Hi Ahmad,
Do you have Sync enabled under the Feature Access operations?  Editing in Desktop requires that you make a local file geodatabase for editing and syncing the changes - ArcGIS Help 10.1 .
I think this also means your data must have versioning enabled from what I am reading here - 00184: Layer is not configured for or cannot be used with the Sync capability—Documentation (10.3 an...
AhmadSALEH1
Hi George and Jennifer,
This is really helpful, many thanks your the best.
first we should create a local copy for editing and then edit and synchronize
