How to change the URL in the GeodatabaseFeatureServiceTable at runtime?
2327
10-09-2015 01:17 PM
URSGIS
I have a GeodatabaseFeatureServiceTable with a Feature Layer for online editing in qml, and I want to change the url of the GeodatabaseFeatureServiceTable at runtime to edit another feature service. But somehow it doesn't work when I change the URL. Could someone help me on this issue?
For example, I want to change the url in the following code:
theFeatureServiceTable.url="http:\\gis......\FeatureServer\0";
when I use       console.log(theFeatureServiceTable.url)      now, the theFeatureServiceTable.url value is not changed at all.
Many thanks!
Wei
HannahFerrier
Occasional Contributor III
You will not be able to simply change the URL of the feature service - you will need to include two GeodatabaseFeatureServiceTable objects in your project - each pointing to a different feature service.
This is the same case for the TiledMapServiceLayer, if you wanted to switch basemaps, you can't just swap out the URL of the basemap service - you will need to include two TiledMapServiceLayer objects in your project.
Not very helpful - but I can confirm that what you are seeing is correct and that switching out the URL will NOT work.
- Hannah
