I had ArcMap 10.2.2 in my computer and accidentally deleted it, how can i reinstall?
4635
10
10-11-2015 02:30 PM
Olorukoti_Elkana_Saning_o
I had ArcMap 10.2.2 installed in my Computer and accidentally deleted the software from my local drive. How can I reinstall it?
JayantaPoddar
MVP Esteemed Contributor
It depends on what folders you have deleted/ or have you uninstalled it completely. Further details would help. Meanwhile, try installing it using ArcGIS 10.2.2 for Desktop setup media. If you come across the option to repair, do it.
Think Location
RebeccaStrauch__GISP
To add to what Jayanta metioned, if you just deleted the folders, check you Recycle folder...you might be able to restore the folders.
Since you posted this in the education folder, is this an education copy on a personal machine? Or was it was installed for you?  I you have the install disks or files you should be able to reinstall (or as mentioned, do a repair).  If you have issues with the license (getting it to re-register), you may need to talk to the person that initially provided the license (if it is a single-user/standalone license).
I emptied the recycle bin on my personal machine.
In a message dated 10/11/2015 6:43:16 P.M. Pacific Daylight Time,
geonet@esri.com writes:
_GeoNet _ (https://community.esri.com/?et=watches.email.thread)
reinstall?
reply from Rebecca Strauch, GISP
(https://community.esri.com/people/rastrauch?et=watches.email.thread) in Education - View the full discussion
(https://community.esri.com/message/559547?et=watches.email.thread#559547)
It was a student software version downloaded and activated from esri.com
reinstall?
typically if it is downloaded,  it is an .msi of .exe ​that is downloaded and that is what you double-click to install the software.  If you can find that file, you should be able to reinstall.  But, I'm not familiar with the licensing on student licenses.  Someone else on this list may know, or you might need to call tech support it your local distributor if reinstalling doesn't find the registration automatically.
Thanks Rebecca for your time and info, I'll have to call the tech support
to help. It was an .msi file, and i couldn't retrieve the file to reinstall.
In a message dated 10/11/2015 8:34:12 P.M. Pacific Daylight Time,
reinstall?
(https://community.esri.com/message/559558?et=watches.email.thread#559558)
Sorry I couldn't help more.  Hope your tech support can get you all set up again.
NICOLAPEDDIS
Occasional Contributor II
If you have deleted everything about your arcgis installation, you can log in your esri account and re-download your copy of arcgis.
Then you can activate your student copy following the steps in your esi account.
If you do not have a esri account you can make a new here
https://my.esri.com/
I tried to reinstall from esri.com/account, but I dont get the access to
ArcMap 10.2.2 downloads.
I dont get the download option. I still have the EVA code from the ESRI
book I bought for the semester.
In a message dated 10/12/2015 7:44:26 A.M. Pacific Daylight Time,
reinstall?
reply from NICOLA PEDDIS
(https://community.esri.com/people/istigatore?et=watches.email.thread) in Education - View the full discussion
(https://community.esri.com/message/559573?et=watches.email.thread#559573)
