AnsweredAssumed Answered
Adding Polygon
Question asked by meenu.monu on Oct 11, 2015
Latest reply on Oct 12, 2015 by meenu.monu
Hi all, Thank U.
I am trying to add a polygon in a button click.The below code wrote in button click.But the polygon not showing. If I will pass some points direct like this then it is working perfect.Where is the problem??
polygon1.addRing([[58.4245719470205, 23.582511030118049], [58.423799470824214, 23.594545845196812],[58.44002147094627, 23.5743298721676], [58.443798021239232, 23.578735174416867], [58.4245719470205, 23.582511030118049]]);
while (CMt <= (list.d.length - 1))
                                    if (Points1 != "") {
                                        Points1 = Points1 + ",";
                                    Points1 = Points1 + "[" + list.d[CMt].EPolyLong + "," + list.d[CMt].EPolyLat + "]";
                                    gname = list.d[CMt].EPolyGname;
                                    GDesc = list.d[CMt].EPolyGDesc;
                                    CMt = CMt + 1;
                                if( Points1 != "")
                                    AddPolygonGraphics(Points1, gname, GDesc);
                                    Points1 = "";
            function AddPolygonGraphics(Points1, gname, GDesc) {
                Points1 = "[" + Points1 + "]"
                var polygon1 = new Polygon(new SpatialReference({ wkid: 4326 }));
                 //polygon1.addRing([[58.4245719470205, 23.582511030118049], [58.423799470824214, 23.594545845196812],[58.44002147094627, 23.5743298721676], [58.443798021239232, 23.578735174416867], [58.4245719470205, 23.582511030118049]]);
                polygon1.addRing(Points1);
//                alert(polygon1.rings[0].length);
                // map is in web mercator so transform the geometry
                var poly_wm = webMercatorUtils.geographicToWebMercator(polygon1);
                var symbol = new SimpleFillSymbol();
                var strhotspot = (gname.trim());
                if (GDesc != "")
                    strhotspot = strhotspot + "," + (GDesc.trim());
                var infoTemplate = new InfoTemplate();
                infoTemplate.content = strhotspot;
                var graphic = new Graphic(poly_wm, symbol);
                graphic.setInfoTemplate(infoTemplate);
                MyGraphicsLayerGL.add(graphic);
                mapDiv.style.visibility = "visible";
                DivesriLogoImage.style.visibility = "hidden";
Outcomes
