WAB not able to delete apps
1655
10-08-2015 12:53 PM
MichaelMiller2
Occasional Contributor III
Using WAB 1.2 and I have two apps that were created for testing purposes. Now I want to delete them and they will not delete. In teh Node dialog window, it reports that "Remove app failed, unable to remove app files. id: 2.
Is it advisable to manually delete the folder from ..\server\apps\id# ?
RobertScheitlin__GISP
Michael,
   Normally you get this error if you have a windows explorer window open with the folder or a subfolder of it selected. You can safely delete the \server\apps\ folder and then attempt to delete it in the WAB again and it will successfully remove the app.
Michael,
MichaelMiller2
Thanks Robert!
