SDE ST_Transform gives wrong geometries from 3857 to 4326
2772
5
10-09-2015 12:47 AM
GianniContino
New Contributor III
Hi All,
I made a transformation of a circle with radius of 1000 mt. from 3857 (Web-Mercator) to 4326 (WGS84).
I issued a strange situation: the projected circle has a radius of around 0.7 meters.
What happens?
Thanx in advance
GianniContino
New Contributor III
Thanx I think I solved.
I was measuring distance in Planar instead of Geodesic distance.
the tool is the one of arcgis atcmap 10.2.2
@neil i know that the shape is such an ellipse, but all the axis where wrong
NeilAyres
4326 WGS84 is a geographic coordinate system based in degrees not metres.
GianniContino
New Contributor III
I know.
But my problem is different:
I insert a circle (radius = 1000 meters in EPSG:3857 Web Mercator, in Meters);
after I transform it in WGS84 (in degrees);
In ArcMap by a tool I measure the radius (the tool returns length in Meters, etc...) and radius is 700 meters, not 1000 m.
I think it's an issue of SDE.ST_Transform
NeilAyres
I very much doubt that the projection is being handled incorrectly.
But what is your purpose for this?
And I ma surprised that your output is still a circle with a particular radius.
Depending on where it has been placed (high latitudes vs an equatorial location), I would expect that the Web Mercator version gets quished into some sort of ellipse in degrees.
VinceAngelo
Esri Esteemed Contributor
You'll need to provide exact details of the version of ArcGIS, the database product, the database product version, the geodatabase version (if not the same as ArcGIS), the exact SQL you are using, and the coordinate values associated with at least one feature. You'll also need to provide how you determined that the radius was sub-meter in WGS84.
- V
GianniContino
New Contributor III
