Street Symbols - Custom Basemap
2614
10-08-2015 06:44 AM
Randy_A_Stapleton
New Contributor III
I am curretnly facing a problem with my street layer for a custom basemap. The problem is that the way in which the streets layer is drawn creates an overlap with other streets (see attached image). Is there a way to fix/remove this? Overlap.PNG
TedKowal
Occasional Contributor III
Go to the ArcGIS Help and look up "symbol level drawing".  By setting symbol levels you can "merge/order/remove" boundaries for lines that connect to each other.
http://desktop.arcgis.com/en/desktop/latest/map/working-with-layers/what-is-symbol-level-drawing-.ht...
TedKowal
MichaelVolz
Esteemed Contributor
My organization has also created a custom basemap with streets and using Symbol Levels with Join resolved the same issue you were having.
Randy_A_Stapleton
New Contributor III
Thanks guys, I appreciate the feedback. This is my first time creating a custom basemap. I'm finding that working with centerline data is a huge task in itself. Any tips on grouping/sorting centerline data?
MichaelVolz
You want to keep the symbology simple for the basemap, but I do think you would want to differentiate primary roads (interstates, state roads, county roads) from secondary roads with at the least different colors such as a grey and white.
