I would like to reclassify only the pixels of one value that are completely enclosed by pixels of another value.
Can someone help me do this?
I've used 10 iterations of majority filter (using four as kernel filter and half as majority definition) to help fill in some of the missing pixels.
What i need to do is to reclassify the value of any pixel completely enclosed by pixels of another value to the same value as the surrounding pixels. On the attached image, I would like to reclassify the enclosed blue pixels to the same value as the green pixels.
I appreciate any help.
Solved! Go to Solution.
See this help page, which describes how to generalize a messy raster imagery classification. In particular, try starting from the second last step, which describes how to remove areas smaller than a threshold (your blue pixels) and fill in the resulting voids using the Nibble tool.
Alternatively, if you really want to consider only the 8 surrounding pixels and reclassify those that are surrounded by all green, you can do so with Focal Statistics to calculate the min and max within the default 3x3 square, then use Con to test if the min = green value, and max = green value, and the green/blue raster = blue value, change it to green.
Thank you very much.
Majority filter would work
But if you want to be selective:
For example, in your image, there are several dual zones where 2 blue pixels adjoin. If you want to replace both of those as well then you can do a combination of
Regiongroup to identify the small areas it will create individual zones from the input data like a sequential list
SetNull to mask the small areas You can also use Con with SetNull but doing the query on the count field
Nibble to remove the small zones
In that way you can remove zones of 1, 2, 3,... x cells even if your maps consists of 2 classes but dozens+ of discrete zones. Remember, raster data are like multipart data in vector world, you need to convert the multipart representation to singlepart in order to process 'fiddly bits'
